mk recall. | on ElectriciansForums
Discuss mk recall. in the UK Electrical Forum area at ElectriciansForums.net
croydon
Just had a return call from mk in regards to 100a main switches.
They have offered £50 to check each switch and a further £70 if they need changing or the stock option of
20 double sockets to check and a further 30 if it needs changing.
Now to decide if i want £500 or 250 sockets!
On their website it sounded like they'd lined up their own contractors to check and replace if necessary, they were just after info from the original installers. Maybe there's more urgency than they first suspected or maybe it's turning into a bigger task than they thought.
Reply to mk recall. in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
