Mk Sentry CU Main breaker positioning | on ElectriciansForums
Discuss Mk Sentry CU Main breaker positioning in the UK Electrical Forum area at ElectriciansForums.net
L
leitrim99
Can a Mk Sentry CU Main Braker Switch be positioned to the right of the Cu as all photos I have seen of the Cu the swich is on the left Thanks
Once you start tinkering with the CU your starting to go against manufacturers design and therefore could be going outside the scope of BS 60439 UK Annex ZA.
I'm sure though MK would do some sort of conversion kit to change there boards around, have you contacted them to ask?
Will do wylex units are orientated the way i want so might use one of them
Used an MK 5+5 dual RCD board today and i wouldnt reccomend them at all, very flimsy and poorly made. No wonder wholesalers are knocking them out at £55+ vat inc MCBs.
Id rather Hager, Crabtree etc...
Couldn't agree more. I had a bit of an obstacle, climbing over customers furniture to get at the board. A bit of a long story but I was setting a temporary supply for builders tools etc. when I took off the front cover, one of the "captive" screws fell out and has disappeared into a parallel universe. The case is so thin and flimsy it was very difficult to get the cover back on. Anybody know where I might get these screws?
Reply to Mk Sentry CU Main breaker positioning in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
