mk6 transit | on ElectriciansForums
Discuss mk6 transit in the Auto Electrician Forum area at ElectriciansForums.net
sneillyboy
Hi Guys
Am helping a mate fit and wire a towbar to a mk6 Transit, have taken cable to nearside rear cluster but there is no right turn wiring here, should I have taken the cable to off side or do I need to wire between to complete the job/
As always appreciate any help
you should see if both sides of the cable loom/s come down the van together. if so wire to that side. if not, you need to wire to both sides.
You may need an adapter unit to prevent your vehicles ECU from thinking those additional lamps are just a 50% increase in load. The towing websites are great for a quick check of wiring compatibility. Also,PLEASE don't use scotch-loks,we have come a long way since the 70's...:conehead:
Mk 6 transit no faults on ecu just tap into loom and do a loop over from the opposite side turn signal
Don't forget to "loop" the opposite side sidelight feed,or it's union illumination on yer trailer! (one out - all out :icon12: )
Reply to mk6 transit in the Auto Electrician Forum area at ElectriciansForums.net
I well remember the sliding windows on ther Mini, and also the manual choke and the foot-operated dip switch. I recently traded in my 18 year old...
    • Informative
Thank you so much for your help with this light work perfect now thank you again much appreciated
