Moisture resistant 2g plate switch - internal | on ElectriciansForums
Discuss Moisture resistant 2g plate switch - internal in the Electrical Tools and Products area at ElectriciansForums.net
DaveyD
Warminster
Hi Everyone
I'm look for a customer who wants switching in his bathroom via plate switches INSIDE the bathroom - no to pull switches and no to switches outside the room. He is out of zones. I can't find a moisture resistant plate switch that does not look external. Have you used one before?
TIA
David
if its a small bathroom and a 2 gang switcch you could add both cables together, so both lights come on together, and put on a wall kout pir, which look pretty cool
Use a flat plate touch sensitive remote switch and use a gasket or sealant round the edge.
The flat plate will not hold moisture, the remote switch will be ELV and moisture will not get behind if sealed (though this is overkill when you think of FCUs, pull cords etc in bathrooms.)
Reply to Moisture resistant 2g plate switch - internal in the Electrical Tools and Products area at ElectriciansForums.net
