Monitor and bulb trips mains.Question. | on ElectriciansForums
Discuss Monitor and bulb trips mains.Question. in the Electrical Appliances Forum area at ElectriciansForums.net
sew333
Poland
I had a good monitor AORUS AD27QD. 3 months ago it tripped electricity in my house/breaker/s.When power back to house.Pc worked fine. But monitor was not turned back. No lights when pressing button,nothing.I sended to rma. Here is shop RMA message:
Shop:"We repaired PSU and sending back good monitor to client"
Is this possible that psu of monitor can trip breaker/s then if psu inside monitor, failed?
Also 2 weeks ago 1 halogen bulb get burned in bathroom and tripped breaker/s too.
My question. Is my house have issue with electricity or just bad luck with that monitor and halogen bulb?
Most likely bad luck.
However, do you ever see the lights getting dimmer and brighter when they are on?
If they are changing brightness by a large amount, you may well have a problem.
No i dont see lights getting dimmer and brighter when they are on.
Somebody said this to me:"I am a registered electrician in the state of Wi and I'm going to tell you to call a local electrician because something isn't right with your household's wiring. You need somebody there in person to find the fault meaning this is outside the scope of what we can help with on a forum. "
So he is right?
halogen bulbs failing often cause fuse/breaker to trip. it's normal. as for the PSU. i have no advice.
Didn't you have the same issue with another appliance recently? And problems with bulbs flickering?
If so, I recommend you get your installation checked out for your own peace of mind.
Nah nothing flickered.
Is this possible that psu of pc tripped breaker and not halogen bulb then?
But pc working fine no issues.
psu is Seasonic TX-750W ULTRA TITANIUM PLUS
Reply to Monitor and bulb trips mains.Question. in the Electrical Appliances Forum area at ElectriciansForums.net
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
