MOnitoring domestic | on ElectriciansForums
Discuss MOnitoring domestic in the Domestic Electrician Forum area at ElectriciansForums.net
fareham
I have a customer with solar edge, that wants to also monitor import, export, usage etc.
i ordered the new Geo 111 but its really difficult to retrofit, having a separate generation meter when we have already installed a generation meter and the solar circuit is in a new fuse board with the rest of the house, so not viable at all.
Has anyone got any others that would work well and supply this info?
Reply to MOnitoring domestic in the Domestic Electrician Forum area at ElectriciansForums.net
If you have an EV the EV charger will also log the supply Are there current transformers on each phase?
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
