more intermediate switch head scratching | on ElectriciansForums
Discuss more intermediate switch head scratching in the UK Electrical Forum area at ElectriciansForums.net
South East Kent
Been spending my time trying to sort out a intermediate switching problem at a customers house. The problem i have is that the intermediate is wired what i what i thought was correctly but the switchs only work if you change the postion of the intermediate switch to then operate the 2ways. Effectivly you have two 2way switches. When investigating i found that the one 3 core from the intermdiate switch to the last 2way had 230v between p-e from the downstairs circuit.(intermdiate is on upstairs circuit.) I therefore assumed that there was a link between the 2. I managed to get a few floor boards up and found the 3 core and it just seems to go from the 2way to the inermediate. I disconnected both ends checked r1+r2 and i/r all good. Still got more to check but was wondering if there was any suggestion as to why there was 230v on this cable as i cannot find a link, as far as i can tell apart from a small section of the stairs i have not manged to have the carpet up yet. When i isolate at ccu the hallway lights will only be dead if i turn off both mcb. Racking my brains at the moment as i have been working my way through he circuits but at the moment it is all testing out fine. I know you will probaly say yes there is a link between feeds and i will have to find it but if anyone has any alternative suggestions. I would greatly appreciate it.
check and make sure the customer ain't been messing. i had one who'd replaced the switches with posh stainless ones. all done correctly except that he'd used a D/P switch instead of an intermediate.
When you say p-e do you mean protective earth? because any live line conductor would have 230V to any earth.
However check at the switches with a continuity tester to see what is happening at the intermediate switch, one to check it is not a 2 way with a blind terminal (odd) or that the intermediate is not crossing over.
I would hazard a guess that one of the 3-core cables at either 2way switch has got the common and strappers crossed over during connection.....resulting in the intermediate switch actualy switching 1 strapper and common instead of the 2 strappers.
Reply to more intermediate switch head scratching in the UK Electrical Forum area at ElectriciansForums.net
How has this been wired, do you have the supply at one two way and the cable to the light at the other two way with cables from the intermediate...
