keane1
Hi. I'm new to the board and have two questions about security lighting with motions sensors.
1) I have 2 new LED security lights and 2 new motion sensors. The instructions says to only install one sensor per switch. Both lights are on the same switch and I want a sensor on each light, one in front of the house and one in back. Is there any valid technical reason to only have one motion sensor on the same switch?
2) The lights are 100 watt LED each. So 100 watts per sensor. The sensor says 500 watts incandescent/tungsten/halogen or 50 watts LED. Again is there a valid reason why the sensor can only handle 10% of the load on LED lighting?
Thanks for you help.
