hi help required if poss?
called out machine not running food shredder quite small
found 15mf cap lid was cracked (cap no capacitance on terminals)
2 caps in series 15mf motor taken of one cap
so bridged out thermal overload got machine to run very slow stopped.
could not get 15mf cap but other cap ok
managed to get 30mf cap so took out bad cap put in 30mf cap instead of using 2 caps
used 15mf cap still for the motor as was before.
set up was
1wire going to first cap through cap at this point 1 cable went 9 terminal board (motor winding W)
then from first cap to second cap & other wire out to terminal board not motor.
as explained replaced with 30mf now not in series as to make 30mf as before but running 15mf for motor
motor ran for whole two days no probs at all going back to look again could be other cap was on way out
but not sure any help would be great??
also do have 3 phase available on site could remove this & put in DOL starter & do away with single phase.
your thoughts would be most welcome
set up was
