Motor controls | on ElectriciansForums
Discuss Motor controls in the UK Electrical Forum area at ElectriciansForums.net
To expand on Darkwood's points, there are different ways of reversing a motor according to the type of motor, type of supply, and the application. Common configurations that require different switching methods include:
  • Single Phase induction: Permanent split capacitor
  • Single-phase induction: Capacitor start induction run or capacitor start and run or similar
  • 3-Phase induction: Direct-on-line starting
  • 3-Phase induction: Star-delta starting or other reduced-voltage starting scheme
  • Universal brush motor or DC shunt or compound
  • DC Permanent magnet
You can probably get some useful pointers by searching for those types of motor along with 'reversing control' or similar search terms.
3 phase induction dol starter mate thank you very much very knowledgable you are
Reply to Motor controls in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
I would agree that the motor is by far the best part to replace. if it is powered and not turning then it is broken. Keep it simple!
