W
whazza22
What should the overload be set to for a three phase 0.5kW motor?
Discuss Motor Overload in the Electrician Talk | All Countries area at ElectriciansForums.net
efficiency when factored in will increase that figure0.85 amps assuming a power factor of 0.85
overload
500 watts / (1.732 x 400v x 0.8) = 0.9 amps approx
This has not factored in the efficiency of the machine which will not be 100% obviously so set the overload at 1.0 amps.
Regards
Dichroic
HI, can you tell me where you get the 0.8 figure from and what it is, thanks, Matt.
Reply to Motor Overload in the Electrician Talk | All Countries area at ElectriciansForums.net
