Motor power factor correction | on ElectriciansForums
Discuss Motor power factor correction in the Electrician Talk | All Countries area at ElectriciansForums.net
K
Knobhead
I’ve been playing around in Excel again. If any one wants a copy of this sheet send me a PM. I’ll also send the updated FLC sheet as well.
A quick note about the PF sheet, for multiple motors you’ll have to decide when during the start up of a group of drives the group PF kicks in. it’s not good practice for it to come in on initial start up.
Just as an aside, years ago I’d installed 2 new MCC panels. Got a phone call from the site engineer “there’s a couple of parcels for you in the loading bay”. Intrigued I went to collect them, 2 oil filled 50 & 60 KVAR capacitors that looked like Noah had forgotten to put them on the ark. So they got cobbled in to the system.
Later I asked him how he calculated the rating, “I didn’t, I found them in the back of the stores”. I’ve just used the spreadsheet, he was 2% out!
Can somebody give sizes of capacitors needed for PFC and starting of 3phase induction motors of various sizes(kw/rpm/design code).At least give a link.
Hi
Can somebody help me , I've finish my L2 electrical intallation , and and in June i'll finish L3 , I just got pass 17edit 2008 new amendement (2011), plus , I've just started an evening 2391 T&I course (will finish in 8weeks time ) ,
I want to do my NVQ , can you help ?
Best Reguards
As the no load current varies from manufacturer to manufacturer the size of capacitor for any motor(kw/speed/design code etc)should be obtained from the manufacturer. Some capacitor manufacturers too give a chart/table to select proper rating of capacitor. I don't know whether there is a code/regulation(BS/IEC/NEC/VDE/NEMA etc) on this matter.
Reply to Motor power factor correction in the Electrician Talk | All Countries area at ElectriciansForums.net
Thank you both @ElectroChem and @Lucien Nunes . Your explanations were thorough, yet simple for me to understand. An extra details I should have...
He knows his stuff to be fair. Or he bluffs very well. 'She was only an organ blower's daughter, but she knew an awful lot about pumping'
6K
Avo - thank you very much for these suggestions. The way I have been planning to have my setup oriented is a rotating wheel full of polymer...
read this: http://www.electriciansforums.co.uk/commercial-industrial-electrical/31498-supply-calculations-3-phase-motor.html and this: Eaton -
E
If you want to save on your monthly electric bill and reduce your greenhouse gas emissions at the same time, you might buy a new, energy-efficient...
Electricity News --
E
