Motor repair recommendations Wilts/Glos | on ElectriciansForums
Discuss Motor repair recommendations Wilts/Glos in the Commercial Electrical Advice area at ElectriciansForums.net
wiltshire
Evening all,
My client has salvaged a car workshop ramp. The casing where the connections/ capacitor are housed on the motor has been destroyed. Can anyone recommend a local firm (South Gloucestershire) that carry out these sort of repairs?
Its not a job I can do.
Many thanks,
James
[ElectriciansForums.net] Motor repair recommendations Wilts/Glos
Deritend or Brammer will sort that, but it look like it would be easier/cheaper to replace it. I've not come across a Nantong Xiong motor before but something tells me there not going to be worth saving.
Search motor re winders in you area.
But motors are cheap so it may pay just to replace it.
Evening all,
Many thanks,
James
Hi,if he is your client,you might want to recommend he sources an original motor,from a current distributor.
He will get away with modifying the ramp,if he is using it solely,and nobody else has use or access.
If not,he needs to check out LOLER and PUWER,as even fitting what seems like an identical motor,without manufacturer/designer consent,is unauthorised modification.
It all sounds very dull...especially when,as youngsters,we used to get our 4x4's up on scaffold boards across beer barrels,to swap gearboxes,clutches,etc...but it is,what it is :)
Thanks for the info Lee.
Hi PEG. It is solely for his personal use. I will make him aware of the points you have raised. However I won't mention about planks and beer barrels though because he does like to save money where possible.
Thanks.
James
Reply to Motor repair recommendations Wilts/Glos in the Commercial Electrical Advice area at ElectriciansForums.net
Did anybody take this on at all? Just curious.
