The local Men's Shed has some machine tools, all 1 phase, typically 1 KW, ~~ 20 years
old. A member asked me to see if I could make them run at variable speed. At present
you can only change speeds by moving a belt from one pulley to another, which is
inconvenient. I found some variable speed units which say they use rheostats. Please:
Do these units work with any type of motor ?
Is there a danger that they will get hot at slow speeds?
Thank you
Thank you
