Despise
I know some of you maybe asking why Im posting here and not on a motorbike forum so il lay it down for you. Basically I want to run some lights on my motorbike just off of battery power for track race use (as the bike doesnt generate power) and need a few questions answered or help.
I have:
Headlight running two MR16 LED lights 1.3watt each = total of 2.6watt
stop/tail light 2.4watt / 1.1watt = total of 3.5watt
Two Plate lights 1.4watt each = total of 2.8watts
Total as whole [ 8.9watts ]
All this runs at 12volts.
what I need to know is what is the best power source to go for in terms of rechargable batteries,longest lasting and weight.
I think i worked out that if the current is 12volts then i do 8.9watts divided by 12volts = 0.75mah (this is the amps an hour i need to keep it running? correct me if im wrong.) And if I did need 0.75mah, how long would 10x AA 1.2volt rechargeables last at 2700mah ?
sorry if im not explaining myself clearly, just im trying to get my head around it all, any help very much appreciated, thanks
I have:
