Motorcycle Dash Wiring Query | on ElectriciansForums
Discuss Motorcycle Dash Wiring Query in the Auto Electrician Forum area at ElectriciansForums.net
P
popmonkey69
Hi all,
I was looking to fit a newer model dash to my motorbike.....
The plug on the rear of the dash is the same but from my limited electrical experience the wiring is different
I think the newer one is canbus but my current bike isnt
Is it possible to modify the wiring to suit the newer clocks ?
I will endeavour to post the two different wiring diagrams if anyone thinks they can help....
Cheers
I have some experience with motorcycle wiring but am not happy downloading an executable file from an unknown source, can you post a "safer" link?.
What make/model bike do you have?.
Its a 2002 Yamaha R6 and the clocks I wanted to fit are from an 2003 R6
Those links were a quick fix by me as I had to extract the diagrams from the full service manual .pdf's
I can post the full manual links off an R6 forum but they are 15mb and 10mb
Reply to Motorcycle Dash Wiring Query in the Auto Electrician Forum area at ElectriciansForums.net
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
Complete guess, but it's probably cheaper to let a separate meter read a CT clamp and send the data to the charger's microcontroller using rs485...
