motorised valve | on ElectriciansForums
Discuss motorised valve in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
had someone today said there mortorised valve has gone 2nd time in a year.... ive never looked at 1 is this common which i doubt so any input will help me . could i just replace like for like no probs?
If they are repeatedly failing it may be because the they are not up to the job they are doing, you havent specified what the valve is for, common sense would say it should last longer than a year especially if its happened twice so you need to check the bumf it came with or download it and make sure its working within all it parameters i.e. Temp, voltage, pressure etc etc ..... i assume its opening up to let a fluid through check their isnt any contaminants building up and blocking the mechanics etc
cheers for replying , yh no good just replacing it, if they ring me back il tell them to get a somone who knows more about than me and il meet him there and learn a bit maybe...... i have read about the vlave sticking and could have build up... il post more on this when i know more
Reply to motorised valve in the Australia area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
I
Cleaning a Magnetic Filter without an isolation valve Hello All, We have a Vaillant boiler, it has an advanced protection kit fitted that gives...
i3_happy
I
