moulded plug | on ElectriciansForums
Discuss moulded plug in the UK Electrical Forum area at ElectriciansForums.net
J
jelswood
Hi,
I have a tv that has the power cable fixed behind a built in cupboard. It's now time to update the tv and dont want to have to take all the cupboard down. If I cut the moulded plug on the tv can I rewire a new plug on as normal?
I guess you mean cut the new TVs plugtop and feed the cable behind the cupboard otherwise it won't fit? You can cut off the plug top and replace it with a appropriately fused BS1362 plugtop BUT check as this may void your warranty on the TV
Don't fuel the fire .... as long as the plug is replaced with a suitable plugtop and connected correctly then it wont void any warranty.... the issue is when suppliers try to use it as an excuse to get out of an under warranty repair or replacement ...if the plug top has been replaced correctly they can't void the warranty based on the fact the moulded has been removed.
If i do a kitchen i always issue a PAT cert for a replaced plug top to give the customer security and the scamming suppliers less room for menouvre
This "Warranty void" thing is a total nonsense. The only issue I have heard of is a refusal by an appliance engineer to work on appliances connected to spur units because they treat removal of the plug from the socket as isolation and they treat removal of the spur unit to disconnect the flex and a qualified electricians job. This could obviously end up being interpreted as "warranty void" by the time the story is tenth hand just because the appliance engineer refused to carry out a repair because he could not isolate the appliance as dictated by his companies working rules
If an appliance is hard wired into a flex outlet it should have a double pole switch to isolate it.
And not give engineers an excuse to walk away :teeth_smile:
Removing the plug from the socket is total isolation and how a lot of companies treat an appliance as isolated, a double pole switch has no lock off facility and while it isolates the equipment it could be turned back on while the engineer goes to his van even removing the fuse from a spur unit does not give reliable double pole isolation so plugs it is
That's just another load of old cobblers!! If an FCU complies with BS7671 as a perfectly adequate means of DP isolation, then who is a service repair technician to say otherwise?? If the guy is that incompetent, he can always use the MCB/Fuse in the CU to isolate, and that won't be DP either!! lol!!
I see what you did there...he said engineer, you say technician...lol
Rightly so too...
Reply to moulded plug in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
well now to throw some stuff on the tv wiring I did ages ago I have a labgear 8 port distribution amplifier mounted in the airing cupboard...
