dougalthedog
Hi,
Looking for advice on the best way of fitting brackets with these tiles:
Monier:*Redland Grovebury Roof Tile | Traditional Concrete Pantile Roof Tile
Clearly if we fit brackets to the rafter, depending on where the rafter hits the tile, we will need a different height of bracket. To make matters worse the rafters are 38mm. I've seen others suggest installing noggins between rafters, is this the best way to go?
Clickfit sounds like a tempting solution as much as I dislike the idea of it.
