Moving 100amp switch box | on ElectriciansForums
Discuss Moving 100amp switch box in the UK Electrical Forum area at ElectriciansForums.net
Surrey
Hi all new to this forum, and require some assistance to a job the is currently being undertaken.
A client is currently having a new kitchen installed and, behind a unit in the old kitchen there is a 100amp switch box, wich is fed from the cut out on the outside of the property. And swa out to DB under the stairs.
The problem is they are expecting a new range oven to be installed directly infront of the switch box, making it in accessible in the event of emergency.
Whats the options on moving this or having this moved to accomadate the new oven.
Hopefully these pics will help
[ElectriciansForums.net] Moving 100amp switch box
You need an electrician to have a look at the job and see what is possible.
The easiest thing to do is probably adjusting the kitchen design as there is a limit to how far that could be moved without getting the electricity board to move the meter.
Chase a metal adaptable with the existing SwA glanded then rear through the existing hole into meter box using new tails or new length of SwA glanded to repositioned switch fuse in the meter cupboard using the big red square on the top right!
Or what @snowhead suggested.
Thanks for input lads, chasing an adaptable box into the wall and relocating a switch in the metre cupbord sounds like the best way to go at the moment. I was thinking henly blocks in the adaptable box to make the joint or crimps, but never crimped 25mm csa before so will most probably go in henly blocks.
Once again thanks for the replys its much appreciated
Reply to Moving 100amp switch box in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
