T
Tygoose
hello all!
new member here and looking for an answer to this question...
have to move a wieredly postioned cu in a small single room. It is about 400mm off the ground??? which i find a bit odd and never seen before. the room is being occupied by 1 year old and the client needs it moved asap. the main incoming is on the other side of wall so extending meter tails will not be an issue. Not checked where circuits cable running but presum running up as it is ground floor apartment/semi house. will be checking tomorrow. If cables are run up and just plastered over any suggestions of how to extract without damage to the right height?
