Moving a fuse box under the 17th Edition | on ElectriciansForums
Discuss Moving a fuse box under the 17th Edition in the Australia area at ElectriciansForums.net
P
P&Q
Hi guys,
I have come across a fuse box which needs changing and upgrading, this is above the cooker and I need to move it. Firstly, I needed to know how far away it needs to be from the cooker according to the 17th Edition. Secondly what do you think would be the best way or thing to do to extend and run the cables over?
I am going to notify the local authority and they will be coming to inspect after the first fixing.
Any help would be appreciated!
Hi and welcome to the forum.
To be honest, this isnt the sort of thing that can be answered on a forum although we will do our best.
There are a number of factors to take into consideration, before even thinking about moving a cu; ie, type of earthing, incoming supply meter (which you cannot touch), age of the installation, main bonding etc etc.
If you say its above a cooker then the cables could be needing replacing, at least the tails to the CU.
Any chance you can post up some pics?
Thanks for replying, here's some pics, hope they help.
  • [ElectriciansForums.net] Moving a fuse box under the 17th Edition
Looks like a bungalow install to me so,
you could pull (hopefully) all the circuits back to the loft, crimp them through to extend them to the new position, put the joints in a suitably sized enclosure and fit new 17th dual rcd board.
However, you will need to consider the sub main from the suppliers cut out as this will probably need a switch-fuse somewhere along its length (if more than 3 meters).
Hopefully, with only 2 non rcd ways at the moment, the new board wont throw any nasties at you.
Just out of interest, have you ever tackled anything like this before?
I'd pull all cable's back into the loft area make a board up with double suface boxes crimp them in the boxes stick on a blanking and mark up each circuit for anyone coming after. How far are you considering moving the consumer unit??
remember all joint's must be accessible proper pet hate. Cheers
Reply to Moving a fuse box under the 17th Edition in the Australia area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
Our house in a row was built in 1971 and we have metric cables with cpcs for the lighting, top of the row imperial and no cpcs.
