Moving Ceiling Lights in Upstairs Bedrooms | on ElectriciansForums
Discuss Moving Ceiling Lights in Upstairs Bedrooms in the DIY Electrical Advice area at ElectriciansForums.net
M
Mills87
Hello,
I have a box room and a second bedroom where the pendant lights are located off centre towards the Windows of the respective rooms. Ideally I want these moving to the centre of the room. So was after a little advice/opinion.
As these rooms are on the first floor it is only the loft above. After a bit of exploration looking under the insulation I came to the following conclusions:
-The wiring for the box room would appear to allow the possibility of just moving the light using the existing cabling. Any problems in this? Leave slack in wiring or cut down to length?
-The one in the second bedroom would not allow this due to its placement in the circuit. What would the best plan of action be? Site a junction box at current location in loft (maintenance free?) and spur off the circuit to the centre of the room and the relocated fitting? Or is it advisable to do anything else?
I'll note here the cables are single+earth, but in the old colours.
Also for my understanding what is the general rules of running cables in ceiling/loft space? As even though most of the wires seem to run either parallel or perpendicular to the joists, in places they do take a more direct or curved path.
Cheers!
Hello,
Cheers!
I take it from your question that you aren't an Electrician?
When I relocated mine I shortened the cables on all bar one where the cables needed to be lengthened and I just rewired it so there were no joints. Easy in the loft.
No I am not. Just trying to understand what my options are and the size of the job.
Cheers.
Cheers.
Whatever you have to do it's not a big job, providing that it's not boarded over and that the insulation isn't too deep.
I say that you can run cables in a loft where you like, provided that they're not run where they're likely to be damaged. So keep them clipped away from areas which might be used for access to plumbing, boiler, or just storage.
Reply to Moving Ceiling Lights in Upstairs Bedrooms in the DIY Electrical Advice area at ElectriciansForums.net
The best and easiest way to do it would be turn off the power and take the light switch out and splice the 2 wires on the switch together. Your...
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
