Moving CU away from service head. SPD at the fused switch or CU? | on ElectriciansForums
Discuss Moving CU away from service head. SPD at the fused switch or CU? in the Domestic Electrician Forum area at ElectriciansForums.net
Brighton
I'm moving my CU away from the service head. About 8m in 25mm2 SWA. Do I need to put an SPD T2 at the 100a fused switch I'm installing or can I get away with just having one at the new CU location? I'm struggling to find options for the service head location. They a lot more expensive and the box is bigger, smaller would work better for me. Also, most DBs now come with SPDs included. Any advice appreciated.
Reply to Moving CU away from service head. SPD at the fused switch or CU? in the Domestic Electrician Forum area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
