moving cu. | on ElectriciansForums
Discuss moving cu. in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
seemed to have bagged another house extension happening in my street. way hey..
but he wants to move cu about 1m to a box on the new wall. but keep existing dno equipment where it sits
as its under 3 meters i can just install new tails.in a duct in the ground going up cavity of the wall.
rcd the tails or not?????????????
- - - Updated - - -
all existing ciruits and new circuits will be rcd'dddddddddddd
Gland and banjo will work but you could gland into a galvanised adaptable box or steel trunking then leave enough cable to go straight though and terminate in the CU, also helps you maintain the IP rating of the CU. I would personally use three core and some decent size cable to bond the box/trunking so both ends of the SWA are earthed.
You only have to bond at one end however I believe it's still best practice to do both, with the gland kit you normally get enough to do both and you'd get no earthing problems... :)
so 16mm pvc/pvc from dno equipment to isolater , 16mm pvc/pvc from isolater to metal adaptable box, swa from adaptable box to new cu on front wall of house( about 1.5m max) and gland and attach swa to platic cu and having fly lead to earth bar in cu.
would i have to have iscos inside adaptable box
.......... correct me if you think im acting the monkey
[ElectriciansForums.net] moving cu.
couldnt resist lol.
Reply to moving cu. in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
