Moving Light Switches | on ElectriciansForums
Discuss Moving Light Switches in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
tomKett
Hi All,
I need to move some light switches from one side of a door to another. There is not enough room to chase the wires back up from the original switches before going accross the top of the door. There is no access to the loft space above the room therefore I cannot re route from above. I am therefore left with 2 options.
1. Splice the cables at the original switch locations and chase the wires down the wall, under the floor and back up.
2. Chiesel into the wall to access the cable, splice them and then chase them over the top of the door. and down.
Anybody got any views?
regards
Tom
Hi All,
regards
Tom
If i was you pal if there are floor boards i would just chase down to the floor lift the boards needed to rout the cables and chace up to you new position.. or if a commersial situation could use some pvc trunking can get some arcatraive trunking what ever you thinks is easiest and looks best..
Hi,
My opinion (for what its worth) is that you will need to make your splice within 150mm of the top of the wall, then runhorizontally along the along the top until you are directly above the new light switch.
Then drop vertically to the switch.
That way the cables will be within the permitted safe zones.
just read you situation again and are you saying there is no room over the door frame to chase inand down to the new position??i'm a bit slow today lol
Thanks for taking the time to reply.
The property is actually my parents so need to make sure the job is tidy!
It is a 400 year old cottage but the floors are now concrete, there is room to chase above the door within the 150mm zone however there is no room to chase wires back up from the original light switch to the top of the door. Therefore I can either break into the wires at the top of the door, or go down and under the floor.
Thansk
Tom
There is some making good to do here whatever solution you use. Therfore I would cut into the ceiling above the existing switch, cut and extend the cable with a JB or Helacon type connector, run it across to directly above new switch and then straight down. With a bit of care you can get the cable into the corner of the ceiling and the wall without making a proper mess, just use a bit of filler to patch up.
Hi mate, I specialise in old cottages with problems exactly as you say. sketch it out on paper with all the possible wiring routes. Then strike off those illegal. If you want to keep the original wire to the original switch- ( you may need it as the feed ) you can just put a blank plate on it and the wire can stay in.(extended if you know what I mean) This tells the owner of the property that a cable is installed there.
Another possible way is to come in from the back of the wall- just ideas for you.
You could always remove the supply to the switch,fit a reciever in the light and use a remote wireles switch
They are designed with this type of problem in mind
like jason smith said, if you jointed the cable at the exisiting position you would have to put a blank plate on to show the cable is coming down the wall there, also this would allow accesibility to the joint. if you chiseled the wall out at the top within the 150mm safe zone then went acroos above the door and down the wall above the new switch position remember that if you buried that join within any making good it would have to be made with a compression tool, ie crimps unless the join was accsesible, which sirkit breakers option would allow, as a ceiling can always have a hole made in it for access.
Reply to Moving Light Switches in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
Thanks again for your help, now solved đź‘Ť
