A tree limb has grown in diameter and is rubbing against the line that comes in from the pole. As you can see in the photo I could move the clamp on my mast higher. This would free the line from contact with the tree. Is there any reason I shouldn't do this? (The limb in question is 20 feet from the house and not shown in the photo.)
Who owns the pole and cables?
If they are yours, isolate power, move anywhere you like and turn back on.
If they belong to someone else, ask them to move them.
Is there anyway you can cut the branch. It’s really a power company problem and all you have to do is call them and an engineer will come out to see what you are talking about. They have tree services that they sub out for things like this
Trying to be serious for a moment, a chainsaw is definitely one of those tools I would not use without training and the proper PPE to go with it as I rather like having my limbs attached and blood on the inside.
If you are doing branch trimming I guess you have these sort of things in the USA:
But obviously you have to be able to safely access the region of the tree around the pole top so you can wield it without the risk of falling off a ladder and/or chopping one of the utility cables by mistake. Cutting back the branches is the best option as trying to move the support wire is only a short-term solution.
But really if the utility will do it for free (or small fee) get them in - don't take unnecessary risks.
@pc1966 the wire belongs to the POCO and they will do it for free. Have a great day
I do not want to remove the limb. Am I right to worry that the insulation on the line will be damaged by movement due to wind?
Yes, it will damage the cable and cause you problems if not fixed. Not just to the cables, it might start a fire with the tree if dry, etc.
But listen to @Megawatt 's advice and contact the supply company - he is one of the well-regarded USA members of this (predominantly UK) electrical forum so knows the rules applying to your situation better than any of us.
why not? unlike us pathetic humans, trees benefit from amputations of the occasional limbs.
It's not a camera. It's a power company pole with what I assume is phase and neutral going down it.
but did you also notice the choc block connectors wrapped in tape? seems the UK bodgers don't have exclusive rights to this method.
@Megawatt will know, but I suspect it is two line and a CNE (so 120V - 0 - 120V TN-C-S with the C/S separation done in the consumer's CU, unlike UK where it is the DNO cut-out), and I guess a pair of Earth rods somewhere in the grounds of the property.
@pc1966 you sound like you have worked over here before and yes we use 2 earth rods. I’m proud of you ??
It turns out that here in southern California the line from the pole to the house is the responsibility of the customer so I am going to slide the clamp up the mast 8". That should clear the limb. Thank you all for the help.
and as the tree grows, another 8" next year. eventually cable could be in sub-space orbit. ???
so cal
United States of America
Moving the drop higher on mast
Babbobubba,
Babbobubba,
