Discuss MPB question in the Australia area at ElectriciansForums.net
The resistance per metre of 10mm G+Y single core cable is 1.83 m'ohm per metre.
20M x 1.83 / 1000 = 0.036 ohms. Your value of 0.78 is way off. Check meter accuracy, lead connections, probe tips etc.
Did you disconnect one end of the conductor before you tested it???
firstly take a look at post 3 mate (Lenny)......test leads are a known cause of high resistances on low resistance ohmmeters. You mentioned that you nulled out the leads so have you checked the plugs where the leads interface with the tester?...Dirt, dust or crap maybe in the plugs?....Try nulling out in the normal way then when zero`d properly just "waggle" the test leads then take another reading....see what you get..........Thanks for comments
Pretty happy that readings are correct. MPB to gas is to high should be equal lower than 0.05
So would you say that MPB needs to be re done?
Thanks for comments
can hide all sorts of nasties can floorboards n cupboards..........there was this house once where we had ripped out the kitchen and behind one of the units was this tatty old dirty pair of knickers...........
Reply to MPB question in the Australia area at ElectriciansForums.net
