Discuss MPBC to Gas Supply not required in the UK Electrical Forum area at ElectriciansForums.net
I think my point of confusion is that there have been posts about plastic covered copper pipes, and posts about entirely plastic pipes (The pictures above have entirely plastic pipe, and a steel fitting with an insulated section.)The one thing to consider is it likely to become extraneous in the future.
Yea I agree on that, with a water pipe its entry to the property must be plastic, & then no MBPC required.Sorry but I’m not seeing what is in fact confusing or contradictory about that.
Do you agree that if you stand inside the property there is nothing you can touch that is conductive to the real earth outside?
Maybe I’m over simplifying this and completely missing your point but I just look at each case and decide if I can grab hold of ‘real earth’ from inside.
Testing can sometimes be a help to ascertain whether it's extraneous or not.is it an extraneous part most probably not.
Can you point out in the regs where they insist this ?The Regs insist on entry to the property must be plastic, in this case it’s not
Over exaggerating the words there…& yes testing would give you the result.Testing can sometimes be a help to ascertain whether it's extraneous or not.
I think thats a valid consideration in the situation in diagram 3.The one thing to consider is it likely to become extraneous in the future.
I find diagram 3 especially of interest.If I,m understanding it correctly ,by inserting a valve including "electrical insulation" in the metal service pipe, then no bonding required.This could be a get out of jail card in situations where running a main bond back to the D.B. could be problematic.
Reply to MPBC to Gas Supply not required in the UK Electrical Forum area at ElectriciansForums.net
