I recently purchased a dartboard cabinet that has an above lighting area with an MR16 bulb, but no wiring. I purchased a new 7w led MR16 bulb, an Aluminum faced Miniature Bi-Pin socket (where the bulb connects to), and a lamp cord with rotary switch. When everything came, I connected the wires, plugged it in, switched the rotary dial to “on”, then heard a “pop”. The rotary switch had burn marks and my breaker was tripped. I thought it was a defective cord, so I got another one and the same thing happened. Any thoughts on what I might be doing wrong? Thanks.
At least over here in the UK, an MR16 lamp (bulb) would likely be rated at 12V and used with a transformer. And applying mains voltage could well be expected to cause a pop, burn marks and a breaker tripping.
That is 24VDC output, I suspect your lamps are 12V?
Yea, my bulb is 12v. Will one of these work than?
Minnesota
United States of America
MR16 bulb wiring issues
DIY Electrical Advice
Thread Tags
Mistaspakles,
Mistaspakles,
