Mr16 gu10 conversion | on ElectriciansForums
Discuss Mr16 gu10 conversion in the UK Electrical Forum area at ElectriciansForums.net
london
hello guys
Looked at a huge 6 bed house yesterday, they all have band new posh mr16 halogens and mr11 light fittings that they want converting to GU10 LED (don't want transformers).
I initially meanaured up all the holes and thought ok let's get you some new GU10 equivalents however I had a brainwave.
The existing fittings are metal fire rated units, I want to just run a cpc fly lead to the previously mr16 unit and simply remove the transformer and wire in a Gu10 socket, I can't see anything wrong with that what you think?
A GU10 socket tends to be class II construction, but do check on the ones you have, so unless you know of a reason to install a cpc this may increase the risk rather than reduce. You would have to make an assessment of the risk.
In general though what you propose is a good solution, still takes ages to change lots of them though!
You've not given any manufacturer or part number of the existing fitting a existing GU10 fitting may be produced to compare against eg earthing , lamp holder etc. to give an idea of conversion .
Reply to Mr16 gu10 conversion in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
