A
alectrician 1
Hi all just after some info and wondering if any one else has had any problems with thier Megger 1552 multi tester.
Ive had this tester for prob just over 3 years now and never any problems but last year after it was returned from calibraton i noticed that (some time after) that the lead with the 3 pin plug no longer worked but the 3 seperate leads did so i thought id buy a set of leads from the new range of testers which has the new type of connections the same as the 3 seperate test leads that worked. Now after sending it away for this years calibration i am informed it has numerous faults, i am awaiting paperwork to confirm this and just wondering if any of you lads out there has encountered any similar problems, thanks in advance Steve
