Discuss Multi-function Tester in the UK Electrical Forum area at ElectriciansForums.net
Extract from GS38
(i) have finger barriers or are shaped to guard against inadvertent hand contact with the live conductors under test;
(ii) are insulated to leave an exposed metal tip not exceeding 4 mm measured across any surface of the tip. Where practicable it is strongly recommended that this is reduced to 2 mm or less, or that spring loaded retractable screened probes are used;
I'd never spend 500+ for any type of voltage detector
surely things aren't that bad that you cant get yourself a decent tester, you get what you pay for!!!!!!
so how are you proposing to get a PFC then?...lick it n see?
Who said anything about voltage detector it says multi-function detector on the packet.
Reply to Multi-function Tester in the UK Electrical Forum area at ElectriciansForums.net
