Multi-tester or individuals? | on ElectriciansForums
Guest viewing is limited
  • Thread starter stratplus
  • Start date
  • Replies 18
  • Views 3K
Discuss Multi-tester or individuals? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stratplus
Hi guys, multi-tester or individual? I'm after a megga but unsure which to buy. I have thought about calibrating. One calibration cost with multi tester or 3 with insulation, loop and rcd.
One multi mate...
No point paying for calibration of separate instruments in my opinion. I don't see the benefit.
Check out test-meter.co.uk, they give forum members a discount.
I was going to say the same, but I couldn't remember the model numbers. The 1553 is the "classic" Megger that I was thinking of (I think!)
Saying that, I use Metrel, MI3000... I get a lot of stick for it, but I can't fault it!
i'm in both camps. megger 1552 that's perfect on all settings except continuity, so use a fluke 1503 for continuity.
You will find most prefer MFTs, but a lot of old hands like myself prefer separates. I have a wide spectrum of testers from which to choose from, over a dozen different MFTs and nearly two dozen separates, but I always seem to gravitate back to the trusty Robin yellow bricks.
The best advice I can give you is to try before you buy, because like most tools it's largely down to person preference, what's right for you may well not suit me. Unfortunately there isn't a universal best tester, despite what you may have heard or read, they all have their quirks which may or may not suit you.
seperates are faster on big pir's.
one guy at DB doing dead tests with ins/cont tester , another guy wandering roung taking loop readings.
twice the work over the same time period - you cant do that with just 1 multi tester.
TBH over the last few years I have collected individual meters as well as my MFT.
Its a lot easier to just take in a Insulation/Cont. meter if you have a fault to find than it is the MFT.
MFT is used solely for final testing
So how's that working then?? Dead and live testing on the same circuits at the same time??
Reply to Multi-tester or individuals? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Google says that North Walney is in the Lake District? Have we moved the wall :)
Marmox multi boards and adhesive? I'm going to be installing Marmox multi boards, on two (internal walls) I'll use 4mm, just so I have a nice...
