Multifunctional tester | on ElectriciansForums
Discuss Multifunctional tester in the Electrical Tools and Products area at ElectriciansForums.net
Oswestry
Hi Guys
Im after not so much a multi functional tester eg the 600 odd pound RCD, IR testers.
Im after a a meter that does Continuity and Will act as a voltage indicator. I want it to comply with GS38 and want it to be a good piece of kit.
Im really stuggerling with this dont know exsaclty what to look for. if anyone can point me in a good direction that would be ace.
A
The fluke is the sort of thing im looking for that looks good any other options to consider???
A
Been looking though a few...
Fluke T5
Megger AVO 310
Fluke 177
Opinions.
I dont know what is good and whats not regarding meters etc.
A
if it's a dmm you want I would say go with a fluke. They are solid, we pretty much only use flukes at work. I have a fluke 287 which is pretty good. More capabilites than I need so will seel it soon. But they go on trials and bet bashed about a lot and never have problems with them. But thats for electronics based work. For electrical I would say the t5 voltage tester as above
Reply to Multifunctional tester in the Electrical Tools and Products area at ElectriciansForums.net
I have the Kewtech that I bought in an emergency when my trusty Fluke that lasted many years gave up. It works! It has single pole testing too btw...
C'mon admit it, I won't judge you. This is where the ol' trusty neon screwdriver makes a cameo appearance. You can prove isolation and tighten the...
