I
ian00uk
how do you use a multimeter to find the switch wire if you have 3 black wires which arent identified with tape
Discuss multimeter in the Australia area at ElectriciansForums.net
what you trying to do m8 explain and will see if i can offer a safe solution for youhow do you use a multimeter to find the switch wire if you have 3 black wires which arent identified with tape
Sorrry m8 not thinking. When i joined thought of Electricians forum ie sparky's then i forget anyone can be on here
If your unsure mabe you shouldnt be trying to sort this but here goes. My fellow sparks may not recomend this but i've tried swich of the mains and i mean all of it, the whole house that is. .............sorry m8 think this is gonna get silly for ya and im gonna get it the neck.replacing normal halogen light unit with ceiling rose. got 3 sets of cables but 3 blacks arent identified and cant get into loft to see where wires go so thought u cud identify switch wire with a multimeter
cheers
Reply to multimeter in the Australia area at ElectriciansForums.net
