multiple cookers | on ElectriciansForums
Discuss multiple cookers in the Australia area at ElectriciansForums.net
T
tommy-trucker
Hi All
Been asked to wire in 5 cooker tops and an oven into a building all rated at 7kw each whats the best way of doing this. The cu is about 20 mtrs away from the kitchen area is there an easy way of doing it rather then individual circuits
Cheers Tom:confused:
it's not 3 phase the building is an old methodist church but the building is more like a scout hut if you know what i mean
Tom
If it's a scout hut,build the BBQs out the back and let them earn their badges.Only kidding mate.If you are going to install that amount of ovens,then the customer may have to have the mains upgraded to 3 phase.:eek:
Reply to multiple cookers in the Australia area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
