Multiple gen meters MCS CERT Question: | on ElectriciansForums
Discuss Multiple gen meters MCS CERT Question: in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
V
VMan
Hi Guys,
Got a 10Kwp install to do, split over 3 phase on two buildings next to each other.
i will have 3 single phase inverters, connecting into a different phase each. I will put 3 x single gen meters (one fore each inverter) as each building has its own sub main.
How would i go about registering this with MCS cert and Generation meter serial numbers? its not possible to put a 3phase meter in as installs are in different buildings.
Cheers
All companies part from NPower accept a single MCS certificate with the meter numbers seperated with a ; or a , (can't remember which but its in the guidance notes). With NPower you will have to generate three certificates.
Reply to Multiple gen meters MCS CERT Question: in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Written in clauses are essential, but should be fairly standard fare to a solicitor. A similar situation exists around where I live with regard to...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
