Multiple lights with switch and end | on ElectriciansForums
Discuss Multiple lights with switch and end in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Paul070977
Hi, Could someone tel me if my diagram below is correct for wiring multiple lights with a switch at the end of the run?
cheers
sorry mate but that doesn't look right,
1, looks like you have your neutrals labelled as a switch line at both lights
2, no continuity of the neutral from jb on the right to jb on the left, no neutral at light on the left
There are few other mistakes, try drawing out again with the above comments in mind and you might get the rest right
posted at the same time. usually scousers are a lot quicker than mancs, but i'm a bit knackered today. spent 5 hours installing SWA and glanding. mostly squatting or kneeling.
I'm pretty sure the OP has figured it out now, judging by other posts on an identical thread on 'another' forum, which for the purposes of diplomacy will remain nameless.
...As long as Lamp V = Supply / 2 ,i cannot see a problem,maybe twice the effort with a set of step ladders when one goes out,but sweet...:stooge_curly:
Unless they are CFLs in which case they both go bang but only half as loud.
Reply to Multiple lights with switch and end in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes the neutrals will be connected together in the same terminal and the earth joined in a 2screw earth connector just behind the switch.
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
