Hey Guys!
I have a little complex task. Its working overall, but i want to understand some strange acting of the motion sensors.
Basically 3 lightning circuits to control with 4 motion sensors which are the same EGLO detect me 6.
1., The sensor 1 lets say M1 and the sensor 2, lets say M2 controls the S1 circuit with 7 spots (5 watt each). The active switched voltage is going to two separated relays' A1, so it is separately giving the sign to the circuit to work.
2., I got 4 spots "S2" controlled by the "M3" sensor -> working fine
3., I got 7 spots "S3" controlled by the "M4" sensor -> working fine
Every spot is 5w and connected the same way (paralell).
When the system is starting up, i put on the switch to make everything work, the M3 and M4 sensors are clicking twice and working good after, BUT the M1 and M2 sensors are clicking three times not in synchron with the others (M3, M4) which are working good. After a little time, M1 and M2 start working as it should be, but its not a normal start like on the two other circuits...
For first time it was like six clicks for M1 and M2 opposite of two clicks on M3 and M4. After i made the relays built in and putting the switched L to the A1 points on the relays. So now its only 3 clicks, BUT i totally dont know how it can happen. Its like these sensors booting up slower than others. I tried to change them but seems the problem is related to the M1, M2 circuit somehow.
If you can help me at least a little that would be nice, i want to understand it.
Thx in advance.
Best Regards,
K
Thx in advance.
Best Regards,
K
