nyb
Hi
I recently purchased a house (built and wired in the 80s).
I removed one of the sockets to do some wallpapering and I noticed that it has 4 hot+neutral (+earth) wires connected to the double socket (and I'm assuming it's all solid core 2.5mm wiring??).
I'm not sure if it's connected in a radial or ring circuit (I'll check soon using the socket next to this one that has the expected two wires to it), but either way, why should there ever be 4 wires connected to a single double socket unless there are 2 spurs off there? The wires are just twisted together; not fused (at least on this end).
Is there any legitimate reason this could have been done? If not, is there anything I should be doing to make this safe? I wanted to clean up the '4 wires shoved tenuously into the socket hole' anyway using wago connectors to connect the wires together and then have a single 2.5mm from the wago feeding the socket. Is this a bad idea (presumambly for a single spur it would be fine?
Any advice here would be great.
Thanks!
Thanks!
