multiple switching of fan | on ElectriciansForums
Discuss multiple switching of fan in the UK Electrical Forum area at ElectriciansForums.net
Exeter
Hi, I have a quick question... Without having to spend time sitting down and working out I'm hoping someone might have a simple solution.
I have one run on fan in loft but wants to be switched and ventilated via 3 separate bathrooms. Now I'm thinking off hand that ill need a relay but I may just be over thinking this.
Any help much appreciated.
Well I know where your comjng from but all 3 bathrooms have already been wired leaving me with a fan having ducting in place and 3 3cores&e 's stranded in loft coming off their isolators.
Did a quick sketch and I do like that idea of the pir's will remember for another job, however this is a 3 storey building 2 bathrooms have this capability 1 does not. The client does not want pir's either as they have already there own switch each. And this scenario would only work if all on same circuit .
Reply to multiple switching of fan in the UK Electrical Forum area at ElectriciansForums.net
Interesting document thanks. But it neglects the half-wave rectification, and also totally neglects the effect of the coil inductance when...
2 3
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
