multiwatt ballast wiring | on ElectriciansForums
Discuss multiwatt ballast wiring in the Australia area at ElectriciansForums.net
J
jonk
Hope you can help I'm trying to change the ballast on a 2x 26w fitting and the ballast i got from the wholesaler is a osram quicktronic multiwatt qtp-m and has 6 holes to terminate my wires yet the old one has 7 on the drawing the extra wire would normally connect between port 23 and 24 has anyone firstly got a clue what i am on about and secondly got any answers ??
your help would be greatly appreciated
Reply to multiwatt ballast wiring in the Australia area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
