T
TF and the wire
I have used this type of safety light barrier on the infeed conveyor to a strapping press. The light barrier has two muting photocells that project beams in an "X" shape across the light barrier. The principle being that as a flat fronted pallet of cardboard approaches, the edges break the beams within 4 seconds of each other and the light barrier is muted allowing the load to pass through. A person trying to enter would not do this and the light barrier would trip the machine.
I occasionally get an error message of U40 "simultaneous muting signals". Could it be that if both beams are broken at exactly the same time, there is a built in safety feature that interpretes this as a possible short between the two photocell outputs?
I have looked through the data sheet to no avail. Has anyone come across this fault?
It would be easy to rectify by altering the crossing point of the beams so that one is always broken before the other.
