oscar21
Nearly Esteemed
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was ever fully installed as we found half a drum of FP above the ceiling, but by the time we arrived on site much of it had been gutted and cables chopped all over the place. We saved the panel and all the sensors/sounders etc and are going to re-fit it all. But before I do I want to make sure that I will be able to program it all if its not already, never touched this make before.
I take it that L1 is loop one and add 15 is address number 15, what I cant see at the minute is how do you set the address on the sensor, there aren't any dip switches or card that I can see. Also it seems that the incoming and outgoing + and - connections are both the same terminal so there isn't an in and out as such with the cable but there is on the loop connections in the panel, does it matter in any way.
