My day 5: build a gsm monitor/alarm for a pump house | on ElectriciansForums
Discuss My day 5: build a gsm monitor/alarm for a pump house in the Talk Electrician area at ElectriciansForums.net
mainline
Patron
V.Nearly Esteemed
Solutions
Cornwall
Will leave it run for a few weeks before tidying it up.
[ElectriciansForums.net] My day 5: build a gsm monitor/alarm for a pump house
I will link to all the 5day threads from the original thread so everybody finds them easy mate. Thanks for taking part you've earned the badge along with the others I just haven't made it yet. 🙄
Not sure if you are familiar with this type of unit, you wouldn’t have as much fun making it, but I used one recently, looks like it would do your job out of the box with an integrated web page for real time monitoring
Reply to My day 5: build a gsm monitor/alarm for a pump house in the Talk Electrician area at ElectriciansForums.net
Yes gsm as in the cellular network, so it will send a text message or call a number when a fault is detected.
ah well no, maybe (definitely) not!
Made a little progress, decided to add battery backup. This is just to get it up and running initially.
Got rid of mains relays and used 5v ones. Sorted out a little charging circuit and change over for the battery.
Some year back there was a case of a young girl killed by being sucked down to the bottom of a pool when being emptied through the power drain...
