J
JackBoy
I have a DC 24v Fan, which at full load uses around 7Amps.
I brought a DC 24v 13A PSU Driver, which when i first tested the fan powered it just fine.
After a week or so went by, I reconnected the driver again, and now the fan doesnt spin even 2% of what it did before.
The fan just about rotates(not very fast spin at all) for half a second then stops for 5 seconds then makes a weak half a second rotation again.
Around 2 seconds after I unplug the PSU Driver or dissconnect it from the fan, the fan spits out one last weak rotation attempt for a bit longer than half a second.
Is the fan at fault or the PSU?
