My Eaton UPS 9390 120KVA is malfunction. The active alarm now is “ALRM: CHECK BYPASS SWITCH” . We get the following status/alarm logs when we try to power UPS and press BYPASS at menu on display:
1. When power on UPS:
- STATUS: CONTROL POWER STATUS ON
- ALARM: CONFIGURATION ERROR 34
- NOTICE: OUTPUT AC UNDER VOLTAGE
- STATUS: INVERTER SWITCHGEAR OPEN
- STATUS: BATTERY SWITCHGEAR OPEN
- STATUS: BYPASS SWITCHGEAR OPEN
- ALARM: CHECK BYPASS SWITCHGEAR
- NOTICE: BYP SOURCE OUT OF TOLERANCE
- ALARM: CHECK STATIC SWITCH 1
- ALARM: CHECK STATIC SWITCH 2
- ALARM: CHECK STATIC SWITCH 3
- ALARM: CHECK BYPASS SWITCHGEAR OK
- ALARM: CHECK BYPASS OK
- NOTICE: BYP SOURCE OUT OF TOLERANCE OK
2. When press BYPASS at menu to force UPS go to bypass:
- CMD: TO BYPASS COMMAND
- ALARM: CHECK STATIC SWITCH OK
We have isolated UPS from the sytem (disconnect the load, disconnect battery) and done the following works to slove the problem:
- Inspect the circuit boards, parts…but no burn found.
- Clean boards: 3 power boards, 01 control board, 01 static switch board..
- Inspect static switch board, not sure OK or not OK.
- Inspect 3 thyristers, they seem OK.
- Remove the static switchgear (K5) out the UPS and test, K5 seems OK.
We have also replaced the Static Switch Board with spare board but this did not solve the problem.
What is happening with my UPS? What can I check more and solve the issue?
If you need more information, please let me know.
Thanks.
Thanks.
