Stuuk1
Me again ;)
Ok, oval conduit... 13mm 16mm 20mm or 25mm?
I'm going to get my hands on a wall chaser so depth shouldn't be a problem, so therefore I'm torn between 16mm and 20mm as I presume 25mm isn't really that necessary.
I know some may say don't bother with capping but I want to use it as its my own house.
Hi Stuuk1,
I use 13mm for 1mm T&E 16mm for single 2.5mm T&E drops and 20mm for double 2.5mm T&E cable drops 25mm for all others or if its a bit tight.
Fantastic, thanks guys.
I take it you all leave the conduit a few cm above the box sunk in to the wall?
Also how do you attach this in the chase? With a crampet of some sort?
I recently got some 20mm tower oval conduit, and after using oval 5 years ago my word it had gone down in quality, it's so thin! I use 40mm clout nails hammered in, nice big round heads hold if in well!
I only really buy 25mm oval and just bang it in with clout nails either side every 400mm or so. I also use capping a lot of the time just depends which is gonna be quicker and easier
I use either the clout nail method or, just lately i have worked out that my chaser is able to cut an exact size for a 25mm, if i put a deliberate ever so slight zig zag in every 250mm it fits in like a jigsaw, ideal!!!
I agree, but my zig-zag is usually un-intentional.....Must get eyes re-calibrated !!!
My Ongoing Domestic Questions...
Domestic Electrician Forum
Stuuk1,
Stuuk1,
