My RCD won't reset after testing | on ElectriciansForums
Discuss My RCD won't reset after testing in the DIY Electrical Advice area at ElectriciansForums.net
NSW
my RCD's wont reset after testing.
I have 6 RCD in my fuse box all in a row (and only 4 MCB - which doesn't seem usual). After pressing the test button, the RCD triggers. The RCD won't however allow itself to be reset.
I have tried resetting with all the MCB turned off as well as all appliances + lights in the house, but still no good.
Any advice appreciated.
  • [ElectriciansForums.net] My RCD won't reset after testing
Hi - if it won’t reset after a successful test, try moving the switch paddle fully down, then up for the reset. Some types of RCBO trip to a mid position and require a “pull down” before they’ll reset.
Reactions: DPG
Reply to My RCD won't reset after testing in the DIY Electrical Advice area at ElectriciansForums.net
I don’t see an rcd here. Is it elsewhere, supplying this board? It looks like it’s in a garage… is there excessive moisture getting into...
Which rcd is it? Is it one for everything, one for a few circuits?
